VZB V-spec
Hi all, I just recently installed an os v-spec in my hyper7, What a difference that made. But i would like some input on things like the 3 head spacers that were included such as when and where to use them, i know less will increase compression and heat. The two carb venturi included. The manual says to use the red (smaller one) on tight technical courses, and the blue when more power is required. Now in my thinking by using the smaller one will increase the air intake velocity there by increasing low end response which would make for a very touchy throttle. Also is there an ideal heat range the engine should be kept in? Thanks alot. If there is a thread that addresses this pardon my post and please re direct me.
