RCU Forums - View Single Post - transition from ff to hover
Old 01-18-2009 | 09:58 PM
homeunt
Default RE: transition from ff to hover
get the heli far forward from the 'landing pad' then start slowing down as you go backward.
then go behind the pad when you are under 40% throttle.
then lower the throttle as you approach the landing pad and cut off when the skids do touch the ground, not bouncing though.
