RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 01-19-2009 | 08:49 PM
  #3530
RTK's Avatar
RTK
Default RE: DL-50 engine
If you are really lean on the low you "might" not be able to kill the engine by closing the throttle plate, either that or it is not completely closing (centered) or you have an air leak. The low needle feeds throughout the whole throttle range also
You do have the idle stop screw removed
