RE: DL-50 engine
I have a DL50 that has around 2 gal. through it and have decided I would like to put a Bowman ring in it. I want to know if there is anything I should be doing to the cylinder or piston when I change the ring. There is nothing wrong with the engine, other than I think the compression is a little weak and I would like to fix this now rather than replace more parts later.
