RCU Forums - View Single Post - ?? How to remove the plug???
Old 01-20-2009 | 11:17 AM
Tired Old Man
Default RE: ?? How to remove the plug???
The welch plug is supposed to be removed using a special tool from Walbro. What happens is that tool is used to knock a hole in the plug at an angle and then used to pry out the plug. Another tool is used to sqaurely tap in a new plug. You can do the same process with items found in your shop. Visit the Walbro website and download some instructions and carb rebuilding.
