RE: VPro Mig Feedback
Well I guess I will be the first then. First of all I love the Mig-15, most beautiful airplane ever, my opinion of course. Hand launch NOT!!!! Nice airplane. Never made it into the sky. Several hand and bungee launches and I never got to fly it. I liked the plane. Not a bad setup for equipment. The elevator servo has something to be desired. If not setup correctly you get differential in the throws which can cause roll. I had to do mine twice before I was happy, and it still was not that nice, you could see the difference in throws by eye if you looked down the nose to the tail. It is a small wing for its size. I have a HET F-20 with that battery, ESC, motor and fan combo in it, from the MIG. It flies great in that. The cheater holes did collect a lot of fodder from the ground when it slid in on launch attempts. Before I put the fan in my F-20 I had to clean it out real good. I may try another one sometime but not time in the near future. I know others have had good luck and others have had the same luck as me, it see, split 50/50. One last point, the decals didn't stick and no matter what I did just didn't want to follow the compound curves of the fuse. Hope this helps.
