RCU Forums - View Single Post - Deception 10 Build Thread
Old 01-21-2009 | 02:37 PM
  #121
doxilia's Avatar
doxilia
Default RE: Deception 10 Build Thread
I also managed to pick up some 1/8" adjustable axles so the wing finally sprouted some legs!
Final adjustments to the struts are still needed. I will epoxy on some 1/8" OD aluminium or brass tubing in the area where the axles attach to provide a snug fit for the axle/strut junction. Then, a small hole will be drilled out in the tubing where the axle is secured by the retaining screw.
As soon as I get the retract servo linkage sorted out, I should be able to join and glass wings and stabs in preparation for mounting to the fuse.
David.
ID:	1116107   Click image for larger version
ID:	1116108   Click image for larger version
ID:	1116109   Click image for larger version
