RCU Forums - View Single Post - Tail wheels on Trainers?
Old 06-08-2003 | 08:22 PM
Woodpile
Default Tail wheels on Trainers?
RCMac,
Don't forget to rebalance your plane. When you move the mains forward, you'll change the CG forward as well.
As for the steerable tail wheel, I also have a taildragger trainer with a rudder that doesn't extend below the elevator. I used a Sullivan tailwheel bracket with a pushrod running from the rudder sevo to an arm I drilled through the brass bearing. I hope you can see enough detail in this picture.
