RCU Forums - View Single Post - Opensource CDI ignition
Old 01-22-2009 | 06:52 AM
  #251
Bigboat
Default RE: Opensource CDI ignition
At high rpm, the capicitor don't discharged to the bottum.
Only at low rpm your using the max current.
The spark is also better at low rpm as high rpm
@Tung,
Was't better when I set the POP to 35 or 30 or 25 ?
I have to choose a number for the POP and I choose 40.
But you can change anything as you like into the Exelsheet.
Set yours to 36 and draw the curve between 27 and 15.
