RE: Opensource CDI ignition
Bigboat, I'm not trying to make you tell how my HV circuit will perform. I'm trying to compare which is most efficient. If my circuit will run for 2 hours on a 2000mAh 6V battery, then you'r circuit is 3 times more efficient and something needs to be changed in my circuit. You see?
