RCU Forums - View Single Post - Canards
Thread: Canards
Old 06-10-2003 | 05:35 PM
Mike James's Avatar
Mike James
Default Canard airfoils
Through the years, I've found that the general rule mentioned in Andy Lennon's material is correct... That is, once the chord of an airfoil drops below 5 or 6 inches, you may as well have a flat plate, due to Reynolds numbers effects. (The exception might be highly cambered airfoils, and I have almost no experience with those, so far.)
The canard on the 1/5th scale Long EZ is simply a sheet of balsa... Airfoils made no difference in testing.
Good luck with your design project.
