ORIGINAL: jsearcy
thanks for the info guys, here are some pics of this hull with all the tc 31 stuff. the hull came with body pins for the hatch, so i changed them out for some valve stems and som piston looking valve stem caps, you can also get the ones at autozone that flash[X(]
Have you run this hull/engine combination yet? If not, the exhaust system may need to be change to get your pipe tuning at its peak. The distance from the plug to the fat part of the pipe is critical. Just my $.02.
I like your hull design. Al
