RE: Shok's FlyEagle 1/7th L-39
Ok new problem.
The brass collet that is supposed to engage the bearing in the control rod, on one side, is too large in diameter and interferes with the control rod when tightened. Bob's solution was to reduce the diameter of the collet, (very carefully with a dremel wheel) until it fits inside the hole in the control rod.
