RCU Forums - View Single Post - Micro/Mini Receivers
Old 01-23-2009 | 04:28 PM
headhunter23
Default RE: Micro/Mini Receivers
http://www.unitedhobbies.com/UNITEDH..._Receiver,_Air
Little less than 2g once you remove the sticker, you can soldier directly or make up some molex connectors... No interfering with others and vice versa, no glitching. If you go outta range it will shut off or how ever you binded it(if you had throttle on during binding I think it defaults to that) Antenna needs to be sticking straight up out of boat and line o site. I've confirmed 250m range in boat(which isn't required for my 12.5" boat as 100-125m have trouble determing which way it's pointed), in plane, is more but don't have gps in plane to figure out distance(guessing 300-400m easy, better if away from servo's or esc etc.).
Ivan.
