RCU Forums - View Single Post - Tower Hobbies Uproar 40 kit ?
Old 06-12-2003 | 07:30 PM
Q-Ball
Default Tigg/
The Uproar wing is built in two halves.Not much room is needed at all but one thing to make dang sure of in any kit is that the building board is FLAT. If it's not,you've got problems before you ever get started. Just don't get started till something is flat. If you have a table or board or whatever that is real close to being flat,cut a peice of sheetrock the same size and go from there.Real easy for pinning. I've used sheetrock from the beginning of time and have no complaints with it at all.It works real well.
You picked a good first kit for starters.When you get to the fuse things will get a little tite in the radio compartment and where your pushrods come thru the rear of the fuse opening.A bit tite but it works out.
Make sure you build the fuse square and straight.
This is a great little plane that does it all or just about all anyway. A real pleasure to fly.
Good luck..Walt
