Tower Hobbies Uproar 40 kit ?
I'm just finishing mine now. Extremely easy build. Yes the wing builds in two halves, but you do have to join them and the wing is permantly attached to the fuselage. The uproar is a good kit if you have a shortage of building space. It requires a relatively small area to build.
The best tip I found on RCU about this kit is to leave the cap strips off of the wing ribs until after you join the wing to the fuselage. The hole in the fuselage where the wing fits is quite tight. Leaving the cap strips off makes it much easier to join. I was happy that I found this tip before I joined mine.
TCBLightning, you're twin Uproar is sweet!
