RCU Forums - View Single Post - Flex Cable Question
Old 01-25-2009 | 09:16 AM
SV27dayton's Avatar
SV27dayton
Default RE: Flex Cable Question
Also if you have the collet that you are going to use you'll want to do some test fitting. It's easiest out of the boat. yo may need to sand or do som creative dremmel work to make it slip in easily. If you solder make sure you have all the strands wrapped tightly or the end will be mushroomed and will be a hastle to slide in and out.
