ORIGINAL: edgersh
hi guys i need help installing a perry pump regulator on a moki 180 in a pica p51 a fellow club member suggested i install a larger pressure fitting in the rear back plate other then the one that came with the pump. also once installed what would be the proper way to start the engine being it is inverted without floodind the engine thanks eddie
The std fitting should be fine
Use the tubing that came with the pump to go between the pump and engine
Normally there is no additional trouble with an inverted engine
The bypass system as described above works very well
