MVVS 35cc on Midwest Extra????
erm rcaerobatics
'moki 210 is ok if you want to pay lots on nitro'
You couldn't be more wrong. Do you actually have a moki?
Moki engines are designed to run on straight , cheap fuel!
You are supposed to get 25-27lbs of thrust out of a Moki 210, so if your less than 16lbs you should get an agressive climb out of a prop hang.
You save a lot of weight with the moki over petrol so it will fly a lot better- especially for 3D.
Nanus Cap with Moki 210 weighs 15 pounds.
TD1's cap weighs 18 pounds with ZDZ 60.
thats a big difference.
