RCU Forums - View Single Post - First Kit build
Old 01-26-2009 | 10:50 PM
Pro-E's Avatar
Pro-E
Default RE: First Kit build
Ceiling tile is by far the best surface to build on....The T-Pins will actually stick to the tile.
I have friends in construction and get me gently used (or new left over) 24x36 tiles. Just make sure they lay Perfectly FLAT.!!!! You'll end up throwing away a few, so get as many as you can.
For your first kit, don't skip de-bonder. Sometimes you may have to re-try alignments.....or just get your fingers un-stuck.!!!
Good luck, and may I just add that you should by alll means dive in.!!
Your discovering the best part of the Hobby.!!
