Tail Dragger This was a 10 yr old ARF I converted
The tail wheel wire goes up into the rudder through a guide tube
use Nylon bolts to hold the gear on. There's a 1/4" plywood plate on the inside with the threads tapped directly into the wood reinforced with CA
This is the main gear I used
http://www.horizonhobby.com/Products...?ProdID=HAN160
This is the tail wheel assembly I used but I made a new wire to go up into the rudder
http://www3.towerhobbies.com/cgi-bin...&I=LXD850&P=ML
