RE: CA Models Funky or OMP Yak 47" ?
[quote]ORIGINAL: HFrank
Thanks Daniel and Spacey. Well, I think the Yak is the way to go. This question is for you Spacey, I could also consider the Fusion .46 and I know you have experience with both planes (Fusion .46 and ProYak .46), which plane is the better ??
I have not flown the ProYak. I do own both the 67" and 52" Fusion. The 67" is a better plane in every way. Not only more precise but more radical. It's control surfaces in the tail are much more effective. The 52" has a higher roll rate but that's the only thing it is better at. I say this because I feel like the ProYak will out 3D the 52" Fusion even though I have not flown the Yak.
david
