RE: Dynamite-15
I assume you have remove the back plate.
pull the sleeve out, than flip engine upside down and carefully rotate the crank to bring the piston at TDC.
Slide the con rod of the crankshaft pin and the piston with the rod will fall into your hand (make sure your hand is there).
push on the crank to remove it, sometimes they slide right out and sometimes they can be a little stiff.
Dan.
