RCU Forums - View Single Post - Stihl - My First Conversion is to begin
Old 01-28-2009 | 06:06 PM
captinjohn
Default RE: Stihl - My First Conversion is to begin
ORIGINAL: robbinsp
ok finally getting back to finish this project. it is a stihl 20cc \ 1.2 cu in. gonna run GloGas! i have a glow plug adapter now and have bought my ceramic engine paint and primer. all excess weight has been removed with grinder and dremmel. it is cleaned like a babys but after a diaper change. It is time to rock n roll...
2 issues.....
[sm=confused.gif]should i make prop hub out of the flywheel or find someone who can make one?
[sm=50_50.gif]the nut that holds on the flywheel to crankshaft is reverse threaded. will that cause a problem.
Just run the engine backwards with a pusher prop and the threads may not be a problem!!! Not sure on that. Capt,n
thanks for any input
robbinsp
