RE: MK Beetle Build
Hello Everyone
There is still some life in southern hemisphere. Work projects have gotten in the way of toy planes.
Since the last update I have glued on the leading and trailing edges and the tip sections. The rest of my time in the shed has gone into getting the saddle fit right. The left side is fitting fairly well but the right side has a gap still. I have to be a little careful to keep the wing square to the fin - a fraction of an inch at the root moves the tip a lot. Also the underside of the leading edge fairing will probably need to be built up slightly.
Cheers
Tarquin
