RE: Deception 10 Build Thread
Andy,
nice looking Gulfstream! Is this the one with retracts?
My comment about exposed motors was really in relation to the aircraft design. Like the GS, the Tiporare has a closed nose fuse which is opened to accommodate the engine. What I was highlighting is that for an electrified Tipo, this is unnecessary and the lines are left intact.
On a model such as the Deception, I don't think I'd care for the lines of a completely enclosed cowl - I like the fact that the engine is mounted vertically and further that ideally you'd use a RE engine with pipe running under the hood. Unfortunately, finding a RE engine these days in the .15-.21 displacement is rather tricky, not to mention the associated headers. Hence, a SE engine being used in this build. Further, I've decided to use a regular muffler instead of a TP in order to reduce weight and because, this model will hardly need it with a .23! (I may end up using the G20/15 if I find the 23 overkill.)
David.
