RE: RC10GT/OS Engine problem
ok get on o.s. and get the manuel to the engine and set it back to factory tunning. make sure your trim is adjusted ok also. after you get it starter lean it out a little not to much. you wanna beable to see smoke coming out the exhaust. if you can get a temp gun and make sure it runs at 230 or below.
