RCU Forums - View Single Post - Flooding?
Thread: Flooding?
Old 01-29-2009 | 10:09 PM
TedMo
Default RE: Flooding?
Ok here's your answer. Since apparently you have 3 lines, fill pressure and supply to engine. Perhaps you have not plugged your fill line after filling. If not then you do not get any pressure to tank. Why it will come out of pressure line when full is because that line is not restricted as is the supply line by means of the needle valve. I didn't originally realize you where useing 3 lines. That should now solve your problem.
