RE: Need help with esky flight simulator
Turn OFF your screen savers!!!!
Windows doesn't look at USB Joystick ( controller ) input to determine if your computer is busy... so it will engage the screen saver after a few minutes.
Since FMS is running you will initially see the frame rate go from a HIGH number to a low one... after that the screen will go black.
Merely turning off the screen savers will cure this.
