RCU Forums - View Single Post - 1/4 scale cowl for OS-160ft
Old 01-31-2009 | 10:14 AM
LesUyeda
Banned
Default RE: 1/4 scale cowl for OS-160ft
If you look closely, the screw just behind the valve cover is holding a plate of aluminum. Another screw goes into the bottom hole. This is used at 4 places around the cowl. If you wanted to get fancy, you could use a flat head screw for the one that will not be removed, and cover it over with spot putty.
Les
didn't take the photo the first time around. I will try again.
