RCU Forums - View Single Post - New 53cc engine now available
Old 01-31-2009 | 10:58 AM
  #759
Sandy69
Default RE: New 53cc engine now available
you do need to drill and tap for a pressure nibble on the side of the carb....if I can do it anyone can....picture is quite clear on location. Tom recommends rotating the carb so the arms are at the top, I did so (minor rebuilt of throttle and choke connections from servoes) Kit includes a new reed block - thicker to hold the V shaped double reed, and reed block is pre-drilled with pressure nipple installed.
Immediate increase of 200 RPM but I'm still running a bit rich
