RE: Prince 25" Mono
h2oskier.
That is indeed a sweet paint job. I like the way you've highlighted the lines & curves of the hull. Much like the way a tight fitting red dress does on a fine looking woman.
Steve441.
It's all looking good.
Don't forget to put a smear of silicone sealant on all the bits you are bolting on.
I epoxied a piece of 1/8'' ply on the inside face of the transom to strengthen the area after the rudder hit a submerged stick or turtle & cracked open the transom. Just a security thing that you may want to consider. Might not be required where you run.
Cheers.
Paul.
