RCU Forums - View Single Post - Sig Hog Bipe - Build Thread
Old 01-31-2009 | 07:07 PM
  #396
SeamusG's Avatar
SeamusG
Default RE: Sig Hog Bipe
MA - as you said in an earlier post your are using Ultracote as the primary covering using Monokote black for trim using the Windex adhesive-activating technique. Did you use Monokote for the black accent stripes or did you use trim tape?
FYI - Rust-o-leum's apple red is a very close color match to Ultracote true red covering. Just needs clear coat to ensure it's fuel proof.
