need help - FOX Engine Model/size?
Picked this up with a garage sale Zero
Says FOX on the carb, but no other marking whatsoever. I measured the bore and stroke and came up with .89cu" (so a 90?). The case is 2 piece with the second half on the back split right across the cylinder centerline. Will add another photo later (tear down)
Was gummed up bad, but turns nice now. Low speed needle was broken as well as the ring having fractures (came out in 3 pieces)
Anywhere to get parts for these? I didn's see them on the FOX Mfg site...
Thoughts?
