RCU Forums - View Single Post - Sig Hog Bipe - Build Thread
Old 02-01-2009 | 09:35 AM
  #397
MasterAlex's Avatar
MasterAlex
Default RE: Sig Hog Bipe
ORIGINAL: SeamusG
MA - as you said in an earlier post your are using Ultracote as the primary covering using Monokote black for trim using the Windex adhesive-activating technique. Did you use Monokote for the black accent stripes or did you use trim tape?
FYI - Rust-o-leum's apple red is a very close color match to Ultracote true red covering. Just needs clear coat to ensure it's fuel proof.
No, I used some black trim tape that I got at the auto parts store. I will have to seal it with clear nail polish. I have had good luck on other planes using instead of monokote.
-MA
