RE: Engine kills always in the 3rd flight !!!
pbuenafama, you are going to have to physically check clunk and tank for leaks, once satisfied everything is ok, tune engine like you normally do, then richen engine 2 clicks. You should be able to tell pretty fast if engine is going to stay running. If not land and richen 2 more clicks or untill engine stays running. If you don't have a tach, get one and this will help you determine how your engine is running. Top of high pitch whine is not always best tuning point.
