RE: Engine kills always in the 3rd flight !!!
Yes, if you physically find no problem with the clunk, then look for some other cause for it to go lean. When you tune your engine, have a helper hold it vertical. Tune it for a solid high RPM in that position. This will insure you don't have it too lean. Also check your pressure line for leaks or holes.
