RCU Forums - View Single Post - Engine Mounting Question
Old 02-01-2009 | 02:20 PM
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: Engine Mounting Question
Korps,
Even if you have no right thrust and you fly the plane it will just want to do a slight left turn under full power. Just cut the throttle back and fly it around. Once you get back home add a washer at a time until you get the flight path you want. New guys to Profile planes find this out very quick sinse there is no thrust built in and add washers to the back two engine bolts to get a couple of degrees of right thrust. Problem solved.
