RCU Forums - View Single Post - Seagull Models Edge 540
Old 02-02-2009 | 09:18 AM
  #744
smh20502
Default RE: Seagull Models Edge 540
I'd like to hear how you reinforced the wing as I just found last night that I'll have to do the same thing.
I was thinking of inlaying a carbon fiber strip across the wing, maybe atop the spar. Also, just behind the spar box section (don't recall what this area is called, between the ribs running vertically. the little rectangle pieces that tie the spars together) Those seem to be junk.
This is why I went with the V2 first....far less work was involved to get it in the air.
