RE: Bubbles in Fuel Line
A sure way to determine and find if you have any leakage from the tank or lines from tank to carb is to remove tank from plane. Submerge totally in water including all lines but with them all plugged,except one that you will blow air into tank with. Any leakage has to show up that way. If all looks good then you are getting air into lines inside of tank.
