RCU Forums - View Single Post - G-62 props and starters
Old 02-03-2009 | 09:25 AM
arobatx
Default RE: G-62 props and starters
Any good wood or carbon 21x10 or 22x10....my personal favorite is the NX 21x10. If you need the weight up front, the spring starter would be ok. Otherwise, with a little practice, starting the OEM ignition G62 isn't a problem without it. I might sway more toward CHignitions Jump Start, rather than the spring starter if you want ease of starting. Robart hinges would probably be best for an application this size.
