RCU Forums - View Single Post - Deception 10 Build Thread
Old 02-03-2009 | 01:09 PM
  #176
doxilia's Avatar
doxilia
Default RE: Deception 10 Build Thread
ORIGINAL: alcarafa
David awesome work and AR to C , whats the scheme for this bird ?
Have you decided what engine your going to mount ?
Very chin... gon
Rafa,
Many thanks. What does "AR to C" mean?
Finish? Classic. Details still being withheld...
I'll be using the ST G20's. I want to break in the 23 so that one will go in first. Unless I find it overpowered, in which case I'll replace it for the 15, she'll remain there. I have another use for the 23 while I intended for the 15 to always power this model so that may eventually happen. The only issue is that I only have one carb for the two engines.
I'm also waiting for an engine mount for the K&B 18 Aero (see early posts) to arrive along with the nose gear (). I suspect the mounting holes of the mount (DB 1519) may be the same as the mount for the ST's (DB 2025) so that might be an interesting option too. I may test fly it with the K&B 18 and a 2.5cc muffled pipe as the weight of that setup is similar to the ST 23 and muffler. We'll see.
David.
