RCU Forums - View Single Post - LT40 Build thread
Old 02-03-2009 | 03:58 PM
dapam03
Default RE: LT40 Build thread
That LT40 looks great Rvator. Thanks Mrbigg. I glued the fibreglass strip with epoxy thinned with alcohol. Then I glued the servo plate on with epoxy also. I'll be using epoxy on the fuse. I just hate the ca glue. I marked the lines and put the motormounts on the firewall. I turned the blind nuts backwards to hold the motormounts while I fitted the engine. Then turned them around one by one pulling them into the plywood. It says to drill the engine holes and gives you a measurement. I'll leave that till last. The weight and balance will be different since it's going to be a taildragger. I also glued the blind nuts on the back of the firewall. I put some tape over the holes so I wouldn't get any glue in the holes.
ID:	1126700   Click image for larger version
ID:	1126701   Click image for larger version
ID:	1126702   Click image for larger version
ID:	1126703   Click image for larger version
ID:	1126704   Click image for larger version
