RCU Forums - View Single Post - ryopi 31cc converted
Old 02-03-2009 | 10:57 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: ryopi 31cc converted
I get about 7100 rpm with a 16x8 prop.
If you converted it to EI that is what you should get too. If you did not convert it to EI I'm not sure what you should expect. I know that you want to advance the timing for more power though. There are a couple of ways to adjust the timing with the mag:
1 Move the pick-up coil about 1/2" clockwise standing in front of the engine.
2 Take the flywheel off, you'll see a slot for a woodruff key. With a dremel tool make another slot about 1/8"to the right of the slot that's there.
