RE: NO power on firestorm 10t
Firestorm, your receiver pack.....where do you have it connected in the receiver? Try conecting the receiver battery directly to the receiver itself. Don't use the switch. When you do, you should here the servos jump a little, then turn on your transmitter and see what happens. If you hook a fully charged battery directly to the receiver and it still isn't getting power, then you probably blew the receiver. Did it get wet at any time?
Post back with results.
Patrick
