ORIGINAL: ram3500-RCU
Yes, if you physically find no problem with the clunk, then look for some other cause for it to go lean. When you tune your engine, have a helper hold it vertical. Tune it for a solid high RPM in that position. This will insure you don't have it too lean. Also check your pressure line for leaks or holes.
+1
