RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 02-04-2009 | 10:20 AM
  #580
richlstubbz's Avatar
richlstubbz
Default RE: Phoenix Extra 330S 60-90 Size
So I have been working on mine a little at a time.
Few things:
The fuse had a part that was broken loose. Simply glued it back on. (I blame shipping)
There was a rib in one of the wings that was cracked but nothing major.
The covering was a bit loose/wrinkled and in some places where not aligned well, so some time has been taken to make it all look pretty. The covering though seemed to be very friendly to work with. It took some time to find the right heat to get a good flow going.
I am adding in some yellows to the plane because I decided I didn’t want to use many (if any) of the decals. Without the decals everything just looked somewhat bland. I am a rookie at covering so it’s been fun. Well this is actually my first real plane and I wont count the lovely RTF Flyzone Cessna I have nor the 3 Target "Air Hogs"..
As I said I will be using a ST-G90 w/ standard muffler and will probably end up trying either a 15x6 or a 16x5 Zinger prop.
Ruder Servo: Futaba S3305
Alerons/Elevator Servos: Hitec HS-475HB
