RE: help with sim question
Hi here is the info for the G4.5. No your computer You can right click on your start button, go to my computer and right click, then click on properties this will show you your system info.
Generation 4.5 System Requirements
Minimum Recommended System info:
Some graphical features may be disabled. Aerodynamic calculations will remain high quality.
Windows* XP or Windows* Vista®
Intel® Pentium® 1.0GHz or equivalent
512 MB RAM
4 GB Hard Drive Space
DVD Drive
3D Accelerated Video with:
32 MB Dedicated Video Memory
Full Windows DirectX® 9 compliant (Pixel Shader 1.4 support)
Optimal System:
For best graphical performance.
Dual Core 2.4GHz CPU
2 GB RAM
512 MB dedicated video memory
(Pixel Shader 3.0 support)
Multiplayer Requirements:
Broadband internet connection
Computer microphone for voice chat
InterLink™ Elite Controller:
USB Port
Compatible FM or FM-selectable transmitter (if using the interface mode)
Note: The connectors on the InterLink Elite cord and included adapters make the InterLink Elite compatible with the trainer jack on most Futaba® and all JR®, Spektrum® and Tower Hobbies® systems. Special adapters for use with most older Futaba and Hitec® systems are available separately.
* Local administration access required.
