ORIGINAL: Paul M
Matt,
Always liked that Hunter of Googly's. Was that his first large project?
Actually Googly built the Dewalt cat I purchased and then started on a 65" MH$ Fountain but bailed on that before he gained any momentup in favor of the Hunter. I ended up the the Dewalt cat and Fountain - think the "Unchained" Hunter is the only big build he has done that I dont have in the basement. That ended up going to Armand in Florida.
The hunter was powered by a Quickdraw 70 inline through a Bonzi clutch to an MH$ gounter rotating box and then a pair of S6 drives. He also installed the adjustable trim kit for the drives but used it once (once set you dont really adjust it)
Balance can be a little tricky - I know Phil had issue spinning his out a few times. I think that was a combination of drives being a little low and balance (weight a little forward).
