RCU Forums - View Single Post - Ugly Stick Build
Old 02-04-2009 | 08:11 PM
Nergall
Default RE: Ugly Stick Build
OK, I finished epoxying the main spars with the 3.1 degree dihedral. I've been reminding myself this means I won't have that big "gluing the wing halves together" task later on because of this.
The angle looks good to me. To me, no dihedral on a shoulder wing plane makes the wings look like they are hanging down. This looks like enough to avoid that without making inverted flight too troublesome.
I pinned the spars down to hold them together on the first one. I tried clamping the second one as well, but I think the pins alone are fine.
Next step was stacking up all the laser cut ribs and knocking the burn off them.
The plans suggest creating a "custom" build table out of two sheets of plywood - one side propped up by six degrees.
I'm thinking I'll just build one half of the wing, then prop the other half up while I build the second half. This means sliding the ribs between the two main spars on the second half, but right now, that doesn't sound like a big problem.
ID:	1127738   Click image for larger version
ID:	1127739   Click image for larger version
ID:	1127740   Click image for larger version
ID:	1127741   Click image for larger version
